rear discs conversion, bled 3 times and still spongey?????
hi done a rear disc conversion on my escort mk4 and bled them 3 times, when i push my foot on the brake there really spongy? i cant get my car through an mot until i sort this! anybody got any ideas please help me??????
If the convertion means the calipers dont seat on the car at the same angle as they did on the car there are off they may still be air in them.
You need to make sure the bleed nipple is at the highest point when bleeding them, may have to unbolt them from there mounts just to bleed them and put them back on to test the pedel (I had the same prob on a kit car a while ago took me a while to figure it out.)
undo the caliper bolts and hold the piston vertical as the rst brackets dont make the bleed point the highest point of the caliper,therefore trapping air.if the problem persists its time to ditch the abs,i had to do both to mine when i fitted discs before the spongeyness went away.
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
