help how do i tell a lsd gearbox
how do you tell a lsd box ive seen one today in a car ive jacked it up and turned the drivers wheel right and if i look under the car the pass wheel is going the opposite way is this right as if isnt ill leave it as i thought it was to spin the same way
As far as I'm aware they spin the same way.
If you take shafts out you'll be able to see straight through where the diff is rather than having a bar in the way.
must be a non lsd ilhave a look for the bar as i have to remove the front subframe or maybe buy it use casings and reshell my lsd mk4 one into it
yeah im a bit unsure about it as head is off car so rocked in gear and span opposites but fez turbs dont have lsd anyway but this is a series one its in but could of been changed at some time
OCD Victim
chowfornow
14
05-01-2019 09:01 PM
