s1 leg and s2 legs same help please
![god](https://passionford.com/forum/images/smilies/dieu.gif)
OCD Victim
Nope. They are different. I think you can use the inner wing, but not the chassis leg.
I know when we rebuilt a S1 a couple of years ago, we got our hands on a new chassis-leg complete from Fords and had to cut a bit off as it was no use.
If you look in this thread:
https://passionford.com/forum/showth...ght=philbotley
you should find all you are after.
If you are getting into a resto. or rebuild that deep, I may be able to help you out with some jig-sheets for reference purposes.
OCD Victim
The jig sheets will not tell you the differences, but will give you all the alignment points that you WILL need to align it up afterwards. If you do not, then it most likely will not be straight in all directions and will have issues afterwards.
If you look @ the thread I directed to in the above post, you can see that the chassis leg itself was retained as it was incompatible, but the top inner wing was replaced using a S2 version.
OCD Victim
surely this can be modified some how though as bought a load a bits tonight for the beast full kit rad front bumper spoiler 3 end caps gearbox front subframe stg 3 turbo 200 quid alright that wasnt it
OCD Victim
Sorry to sound off, but no matter how many times you ask the same question in a different form, it will always be "the bottom section is different".
just re looked at the thread and took the laptop out to the car and looked i see the difference mk4s have front panels attachet to cross member and mk3s are seperate i have a friend with a mk3 cabby for scrap that leg should be same as my s1 shouldnt it
OCD Victim
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Yep, as long as the chassis leg and inner wing is the later single-bolt job it should fit fine.
yes it is the single strut top mount one thanks a lot ian if you wouldnt mind id like the jig dimensions as ive found somebody local to do it for me
OCD Victim
OCD Victim
Okay, I have the jig sheet, send me your email and I will scan it and send a copy over to you tonight or Saturday
155lee
14-09-2015 07:37 PM
