ofam and 21psi??
ofam and 21psi??
going to be putting my new ofam ecu in car when i get lambda n AFR. i read somewhere the standard fiesta rst engine will do 21psi at stock??
if this is true i want to run this in my fiesta rst engine with steel rods and forged pistons at 21psi.
i want to try and achieve around 250 bhp and around 230 lb ft.
i had mine rr'd at 14psi 205.7bhp and 186.9 lb ft which is pretty good i suppose but i want that little bit extra.
what is needed to achieve this? i dont want to go 1.8 or 2.1 bottom end just 1.6 will do. and help will be great thanks
Hi dude, technically the ecu is up to the job.. If you want to run more boost a 4bar map sensor will be required.
I personally would recommend steel rods and forged pistons... or at the VERY least some ARP con rod bolts... with standard rods you really need to keep the rev limit around 6k IMO.... I use standard pistons and steel rods.
Rob,
Rob,
My spec is 1600, steel rods, forged pistons, lightened and balanced bottom end, lsd box, beiges, bayjoo, full front mount, t3 hybrid stage 3 ( i was told when bought), mfi fuel pump, where can i get a a 4 bar map sensor as mine is 3 bar map.
The lad i bought engine off said he was running 21psi at had it running 232 bhp on beiges. How are vxr injectors, wat could u get 250bhp out of them and do the fit direct replacememt or do i need fuel rail?
Sadly 230bhp on beiges won't happen. Personally I would highly recommend siemens deka, vxr injectors are okay to around 240bhp on a cvh due to the poor BSFC.
As for the 4bar map sensor, they are supplied as an optional extra with the OFAM, you can get it as an upgrade too.
Your engine spec seems good, and capable of good power. Who is tuning this for you? I would have a chat with them when they start mapping, they can gradually (and safely) increase the boost whilst making sure there is no det.
What kind of boost control do you have?
Rob,
Rob,
Ultimately, with your engine turbo spec and injector size will dictate power to a certain extent.
Over 200 is very easily achievable with the correct turbo and injectors. A proper stage 3 turbo and siemens dekas should be good for high 200's like 280 comfortably.
Rob,
Rob,
What turbo do i upgrade to and where can i get some injectors to get me that high? I use mikeanics in congleton, but not sure if he will touch ofam?? I need learn it myself really
Cameron
14
09-08-2015 06:28 AM
Oppliger Motorsport
02-11-2013 11:46 AM
