Fuel Accumulator
st170 breaking
are you sure the fuel gauge is correct?
frst's dont have an accumulator so i dont think its required for this but maybe there is a problem with the tank such as from non injection car or something
(i have an accumulator)
Im not sure tbh, the accumulator is supposed to maintain fuel pressure when the engine is off, and acts a bit like a capacitor. If the fuel pump see's a very brief lack of fuel then I think the accumulator would maintain pressure. However this would be a very brief event. As Karlos says pressure should be equal through out the system, this would be true for a longer 'event'.
If the accumulator had a one way valve on its intake it would work.
Rob,
Rob,
Ive got an EFi in tank pump, and i never got the issue under hard cornering until i turbo'd the car and fitted an uprated pump. But i guess as the demand for fuel rises and any momentary shortage in what the pump can draw will have a knock on effect.
I don't really have the funds or desire to go for an external pump and swirl pot etc... So was hoping an accumulator could help?
If not, maybe an MFi tank/pump feeding a small swirl pot in the spare wheel well the on the the filter/fuel rail.
Its only under 1/4 of a tank i get the issue, also the EFi tanks have a swirlpot inside, albeit a very poor designed one!
This might explain the problem I had the other day with mine, I went round a long bend at full chat and the car coughed and chugged so I let off and got scared and drove it home off boost!
It was under 1/4 of tank though, never had it happen before but I've never really given it full beans on a low tank before...
I'm also looking for an MFI tank Roger, I get fed up of dropping the tank to check the pump!
Ask me a question!
When i turbocharge Vans or such like (Bantams, combi etc) i add an external swirl pot and pump, if the customer want to save a little cash and avoid a different tank or custom setup made.
An external swirl pot is around £60 off ebay and pipework is not alot unless you want to use decent connections. A lift pump is around £55 so i guess for £150 ish you could stop the fuel issues and have a decent reliable fuel system.
Jano, that sounds like a good option... Can you post a pic up of a similar setup? What do i do with my in-tank pump?
Matt - the trouble is you dont want it losing fuel a running lean mid corner and melting something or detonating! I mean short-term the answer is to keep the tank pretty full but i think either an MFi tank/pump and swirl pot (purely because the MFi pump is such a high pressure) or get a swirl pot etc fitted to our tanks as Jano says.
Ask me a question!
You could use the pump in tank as the lift pump to swirl pot, then buy an external pump to feed the fuel rail. Return to a swirl pot, so the swirl pot will always be full and the return from the swirl pot back to the tank.
Same as what i have on my own cars but use an external pump as a lift pump.
1 external pump
1 swirl pot
lines and fittings.
1 external pump
1 swirl pot
lines and fittings.
