Mondeo 300mm brakes
Hi all. Searched the forum but can't seem to find a solid answer to my question. Does the mondeo 300mm brake conversion fit under standard s2 wheels with some grinding? Has anyone tried? Some people say yes and some no but want a clear answer for defo. If not i'll have to settle for cossie brakes.
Cheers. Alex
Cheers. Alex
cheers mate. yeah cossie would be the easiest but was just wondering with a bit of effort if the mondy ones would fit. i'll wait and see if anyone has tried it if not i'll decide wheather to chance it and try mondy ones or just go for cossie.
cheers. Alex.
cheers. Alex.
No straight answer then lol. I'm wanting to know if they fit under sharktooths. Think the only way is to try it. Not simple to do. If someone has a mk4 hub I have mk3 mondeo calipers here to try
that was a test fit for a picture they are the proper way don't worry!
Alot of grinding, took maybe 4-5hrs of grinding then fitting then grinding more etc etc, pain in the arse but looks good!
Thanks, Joe
Thanks, Joe
There are two different calipers for the 300 mm disc's one was on the early st220 petrol models and st170 and then the STD mk3 type which I found worked better at speed! I used mk3 disc's before as offset is better suited to escorts but this requires drilling 3 holes in the disc to match the escort stud pattern
15, 300mm, alloys, brake, brakes, conversion, escort, management, mondeo, ofam, passionford, rs, turbo, upgrade
