Series 2 custom charge pipe
Im going to get the grinder out at the weekend and fit my pro alloy 500 cooler also gonna put my rs 1600i rocker cover, as the charge pipes are on either side im going to have to make a custom one off the throttle body. Does it matter what shape it is ? as in if i have a 90degree bend from throttle will it effect flow ? or does it not make any difference ? ? ?
I had this on my old engine in my XR2T, only took it off as i went for cossie managment and EFi manifold.
There more pics here http://gingersphotos.fotopic.net/
charge pipe
Got any more pics mate ? thas what im thinking of doing but leaving the throttle body at the normal angle and running the pipe tight to the cam wheel. Who made the bend for the throttle body ?
Re: charge pipe
manifold
Yeah thats the sort of thing, except mine will go to the left wont have to cut mine though, managed to get sum gripes around the top breather and un screw it just a case of drilling it in new position and securing somehow
Re: charge pipe
I was going to do what your talking about but went this route due to the breather on the rocker cover. I was a lot easier, just made the pipe on the cover come out at a 45' angle towards the passenger side. I made the throttle pipe myself.
Thanks bad boy rs It was make by a bloke that had a Red MK6 with a turbo zetec engine.
Hi rsdan123 Sounds like me. my car was a 1.6 turbo back then.
Its now a 2.1 ZVH so hope to get some Fast times this year
Re: manifold
think you might still have to cut the whats left of the pipe and get rid of the fins on top of the rocker cover.
i wanted to keep the fins, but i couldnt get the pipe to clear.
charge pipes
I see what you mean mate jus looked at your pics again, think i will have the same problems
anyway,
Went up the garage earlier and cracked on , bumper off, radtec front mount out, and then got carried away with the hacksaw theres quite abit of chopping to do, was a bit heart breaking hacking away at my pride and joy but fuck it, because i love modding
will get some pics up at the weekend
anyway,
anyway,
anyway,
Nice rst you got there mate
I'll be looking forward to some pics as i just ordered my FMIC and the pipe work also has to go the other way as it's a single pass....with a 600x300 cooling area so have to grind some metal away i think ...
At the moment i've got a reverse charge carrier from pace but looking for a home made inlet later this year...
Thanks mate, will get some pics up tomorrow gona be down me garage all day and hope to get the intercooler mounted. What side do you need the throttle body ive hot a t16 rover turbo inlet sitting in my garage if u fancy trying that i was going to use it but changed my mind
Throttle body needs to be @ the timingbelt side , but that's how i think of it now....
First get it runng on EFI and then we'll see..
I'm not from UK so i'll think it over ass you'll have to send it overseas then....
What are you lokking for for the inlet?
Looking forward to those pics
cheers fella, yer i am pleased with it, but soon itll be efi and look abit different like moonie said.
sorry for sort of hijacking your post bad boy rs
Not a problem mate
Well ive jus got up as ive been hanging all day after drinking shit loads of fosters yesterday on an all day session. Havnt got anything done on the intercooler, was up the lockup for a while yesterday morning and realised id cut to much of the front panel out which pissed me off, but ive kept them so will get them wlded back after the cooler is mounted. It also turns out that my mate that had the cooler on his motor had to cut away some of the strutial part of the front panel above the toweing eye, im not up for that so im going to mark up the cooler and get the bottom part cut off and wealed up so its slightly smaller. Turned into a bit of a nitmare realy but thats life will get some pics up of my butcherd front panel tommorrow
Not a problem mate
Pics Pics Pics???
Will get my single pass cooler upcoming week i hope...
It's 770 mm wide in total so have to do pretty much cutting i guess (6)
