Arp con rod bolts
Old Oct 29, 2011 | 04:10 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Default Arp con rod bolts
Am i correct in thinking you cannot re-use arp con rod bolts?? or would they be ok? any help is appreciated.
cheeRS
Old Oct 29, 2011 | 07:35 PM
Rick's Avatar
Rick
ideally you should measure the length before you first use them. I've never found one that has stretched though so you will more than likely have no problem re using them.
Rick
Old Oct 30, 2011 | 11:46 AM
milesy23rst
PUG 306 GTI-6
Thanks alot rick, any ideas what they should be torqued up to mate?
Old Oct 31, 2011 | 09:21 PM
milesy23rst
PUG 306 GTI-6
Anyone???
Old Nov 1, 2011 | 12:17 AM
Canada1's Avatar
Canada1
What connecting rods are the ARP bolts for?
Once this is known, the correct part number can be found along with
the correct torque (or stretch value).
Old Nov 1, 2011 | 10:44 AM
milesy23rst
PUG 306 GTI-6
They are for the standard con rods m8
Old Nov 1, 2011 | 12:10 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Every bolt stretches including ARP's.
In fact your are ment to stretch an ARP conrod bolt to the stated value when fitting.
These are for PEC rods but gives you an idea to what is required.
If you email me the part number of the bolts i will give you the correct measurements.
Old Nov 1, 2011 | 12:18 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Rick
Agreed, they nearly always seem to spring back, only ever had one stretch and it was secondhand before it got to me and had probably been overtightened previously or may even have been a copy sadly!
Old Nov 1, 2011 | 12:19 PM
Chip's Avatar
Chip
You are confusing what Rick is talking about when he says about stretching, he means that once you remove them, they should return to their original unstretched size.
They should never been taken past the point of elascicity so they permenantly stretch.
Old Nov 1, 2011 | 08:11 PM
Canada1's Avatar
Canada1
The part number for cvh ARP rod bolts is 151-6004 an 8mm bolt.
Stretch 0.0055" to 0.006" or 25 ft. lbs torque using ARP lube on the threads and under bolt head.
Old Nov 1, 2011 | 09:06 PM
milesy23rst
PUG 306 GTI-6
Thanks alot for that much appreciated, is there any other lube you can use as i haven't any of the arp stuff??
Old Nov 2, 2011 | 08:51 PM
Canada1's Avatar
Canada1
I would only use ARP bolt lube with the 25 ft. lbs. torque spec.
However, if you use a different lube (or oil) you will have to use a stretch gauge
to properly torque the ARP bolts.
There has to be many dealers and shops that have ARP lube around?
Old Nov 2, 2011 | 09:03 PM
milesy23rst
PUG 306 GTI-6
ok i will see if i can get hold of some, am not in a major rush as took my bottom end apart and its fuckked!!!! big ends, mains, crank, rods, flywheel so its going to be off the road for a while!!!
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
stevecfrst1
Sep 30, 2015 05:18 AM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
