heater not working..
hi folks,
1990 S2..
the blower does not work. when driving warm air does come/filter out the vents, but no blower is working.
what is the most likely candidate- the switch or the motor or the fuse??
cheers
1990 S2..
cheers
I would check it in the reverse order, fuse, then motor, switch, the motor is easy to get to, check for live and earth at motor (or even try powering it up) I have seen the motors seized before, never had a problem with the switch tbh
if the motor not running put it straight to the battery few jump clicks can kick start it always leave the switch on at least number one so it works and keeps the motor running !
hi mate i had exact same prob a few days ago. i held a wire from positive side of battery to connection on top of blower i found it was fine (obviosly turn heater swith on in car first) found out after a few tests that my fuse hadnt blown n just needed cleaning as it had built up crap onit over time dont know what its called lol
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
