fooking thing
i have recently had my car setup, if its been setup with an air leak and the air leak has now been sorted would this have an effect on the performance as it still has got the boost but it seems to be holding back.
all it was the boost hose that connects to throttle body wasnt tight so on boost all the pressure was leaking out of it, all is good now, going back to nms on tuesday to have clutch fitted and abit more power
cant wait. it was loose as ive just had inlet manifold gasket changed by a local mechanic and he forgot to tighten it up,
It Wasnt Me!
So it was NMS who set the car up?
how was it spotted their was an air leak?
Prob wouldn't have noticed it on startup as that hose is fairly 'fitted' but on boost I reckon it would have been obvious....rich mixture/hissing?
see that's the prob with setting cars up on the road over RR, haven't got someone standing over the top of it to notice these things if the operator misses it from AFR....
it wasnt leaking when it was setup it been running perfect been to fordfair and driving it about quite abit alot on boost then all of a sudden whilst on boost the manifold gasket blew out. then the mechanic i took it never tightened that clip up which made me think it was setup with an air leak as i didnt know the clip was loose but its running fine now ive tightened the clip up.
07-10-2015 12:56 PM
Mark_
40
02-10-2015 04:40 PM
rsguy
44
29-09-2015 03:29 PM
