Injector sizing/flow rates
Ive been using the following formula to figure out what injectors i want to run on my ms... Altho for the time being im going to stick with beiges.
Im somewhat confused...
Injector Size = (HorsePower * BSFC) / (#Injectors * DutyCycle) = flow rate of injectors in lbs/hr x 10.5 gives you the cc/min flow rate - correct?
According to this formula to get 130bhp from a cvh (standard power) you need 250ish cc/min injectors. Thats beige injectors (240cc/min) for standard power...?
You get cars running beiges at 180-200bhp, which according to the formula you need 380-400cc injectors...
Im confused, can anyone help?
Here you go mate:
http://injector.com/injectorselection.php
I agree, it doesn't really add up. Running at 100% duty still only gives a power potential of 150(ish).
But, if you reduce the BSFC to 0.5 you get a power potential closer to 200bhp with 100% duty and 240(ish)cc injectors....
So in theory, a higher fuel pressure, better BSFC and a duty of over 90% maybe how people get close to 200bhp... plus some pub figure talk and a gammy dyno and their laughing!
In reality, a large injector is no problem. As long as its spray pattern is still good at small openings. The common problem with large injectors has always been a rough, rich idle...
Rob,
Rob,
*** Sierra RS Custard ***
On sequential I find 1000cc will still idle mint on a 2 litre, so equiv to 800cc on a 1.6, obviously on semi seqential like most MS users run though you'd want smaller by approx half.
So you may as well just whack a set of 400cc or so in there and have loads of headroom, it will still idle perfectly if mapped right and its not like you are trying to get through a cat test anyway.
Going back to the numbers I agree that 0.6 is probably a bit high, unless you are running very rich.
Hiya Chip! I owe you a txt mate sorry I didn't reply dude.
Which injectors do you use? I've been told that large modern injectors like Deka's or Bosch EV14's are still very good at low PW's but i havent put that into practice yet! Most MS users i know are still using batch fire, im yet to experiment with semi-sequential but will be on fully sequential next year. Need to have a catch up mate, maybe next time your lot are having ribs? I've got a few mapping questions I want to bug you with before i rent out a RR!
Rob,
Rob,
I like the siemens range of high impedance injectors, although I had 96lb low impedance rochesters in the nova when it was running a big power vauxhall engine.
Yeah would be good to catch up mate.
Mapping on the rollers is quite different. Matt @ Mtech is a bit of a drive from you but does some good deals on renting out his 2wd rollers and is very familiar with tuner studio if you get stuck, so might be worth giving him a call. Feel free to say I sent you.
The problem is that people with 130 hp cars are telling everyone that they have 200 HP.
240cc/min injectors will not make 200 HP - not even close. Especially on a cvh.
Sorry to bum into this thread, but if im reading this right, my beige's wont get me my 200hp on MS, but i cant go big injectors, cause i still need to pas a cat test?
So how about rover 440 injectors.. or would i need some new ones?
Got a chance to buy some used ones.. what would be the best?
Bosch EV14 550cc
Bosch 444cc dyser
Siemens 630cc DEKA
Sorry for all the questions :S
Bosch EV14 550cc
Bosch 444cc dyser
Siemens 630cc DEKA
The beiges come as part of a "195bhp stage 2" upgrade for a fiesta rst, giving an estimated 180-200bhp, ive also seen rst's on the rollers running beiges at upto 210bhp! Ford also produced the fiesta rst with 180cc injectors making 133bhp, which doesnt work according to the formula ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
So what bhp are 440cc's good for? Karlos topped out at 230bhp with these - i find it hard to believe that you need an extra 200cc's of fuel to run an extra 20bhp!
Can i use MS to run my beiges for the time being?
The ratings given for "chip upgrades" are also very optimistic. Again BIG numbers make more sales - this is just sales and marketing tactics used almost everywhere.
The 240cc/min can be increased by increasing fuel pressure. Also upping the duty cycle over 80% can provide more potential power - although a reduction of injector life.
lets take a look at your chart at 200 hp.
100 Lbs/hr = 1050cc/min
With 4 injectors at 100% duty cycle = 1050/4 or 262cc/minute.
This also assumes maximum efficiency - which a cvh engine does not have.
Kinda shows that a 240cc/min injector will never make 200+ hp in a cvh.
Take a look:
http://www.rceng.com/technical.aspx
This company knows what they are talking about.
By the way a cvh is very inefficient and the BSFC number is at least 0.6
Take a look:
Your calculations are correct, but it`s not injector size chart as you can read. Its gasoline chart. You may run 300cc with 500cc size injectors. But you only need that much gasoline to gain specific amount hp.
Just shows a 240cc/min injector cannot make 200 HP (with 4 injectors) even on a theoretical basis.
Sure a 500cc injector can inject less than 500cc/min.
Rick, that goes some way to explaining it.
I don't know how this fits the formula, but E16RST produced around 320bhp on 525cc cossie dark grey injectors....?
Perry i understand what you are saying but the figures just don't work - well i can't get them to anyway. A standard frst produces 133bhp which according to formula needs 250cc injectors, they only had 180cc injectors as standard so they mustve be around 90-100bhp? Im not trying to row with anyone, just trying to get my head around this.
Fiesta blues should be Weber 190cc as XR3i has.
Look my chart 4x190cc= 760cc/h 720-~15% (85% injector duty)= 646cc/h.
646:10,5 (lbs/h)=61,52lbs/h
Injectors duty % may be closer to 100%, so stock 130 hp in Frst case is possible.
Stock injectors won't be run any where near 100% duty, the only two things that could explain it are over zealous dyno figures or as Rick says, they flow more than they quote for. I'm not sure but the quoted flow figures of 180cc injectors maybe be at 2.5 bar? When stock fuel rail pressure is 3...?
Rob,
Rob,
Perrys link
Makes interesting reading but also works out, using the calculator that is on the page that to make 133bhp, you need 264cc/min fuel injectors - surely its not just me thinking thats well off the mark?
Perrys link
Another possibility for extracting a bit more power is to raise fuel pressure. At 60 psi the 240cc/min becomes a 282cc/min injector. Even at a 100% duty cycle and 60 psi fuel pressure the max power is 180 hp.
It is not off the mark at all. I believe you have been believing very optimistic dyno tests or guys bragging how "big" their HP numbers are. The cvh engine is very inefficient and requires far more fuel to make the same HP as a 4 valve zetec for example. The cvh BSFC numbers are very poor.
So for 282 I would epxect to see under 226bhp
And for 240 I would expect to see under 192bhp
But thats on modern multivalve engines, so if the CVH is less efficient like you say (I dont know if that is the case or not, never tested it) then it would be less.
Im just gonna throw the towel in and settle on the fact i can't get my head round this...
I find it hard to beleive that ford would quote the frst as 133bhp when in reality its sub 100bhp according to that equation... The only way i can think to explain this is that the equation is missing something or isn't linear!
The formula does work for the frst.
I entered:
133 HP
4 injectors
BSFC 0.6
85% duty cycle
Result = 248cc/min injector
I think that's almost perfect?? What is the issue here?
The factory car only had 180cc injectors NOT 248cc injectors for 133bhp
180cc/min will not support 133 hp even at 100% duty cycle.
Anyhow, who cares - believe what you want to believe - I can't convince you.
The world is round not flat
What? Why are you trying to convince me I'm not disagreeing.
I stand by my origional statements of over zealous dyno's and pub figure talk. However I don't think I would argue With the origional figures too much, they have been tested many times. So I would think ricks suggestion of higher than quoted flow figures may explain it.
I found that the Fiesta RST was equipped with 197cc/min injectors - information given by a fellow on RS Turbomania forum.
Here is a good table for HP per injector at different flow rates and different BSFC numbers.
http://users.erols.com/srweiss/tableifc.htm#ITABLE
133 hp is very possible with 197cc/min injectors
Using BSFC # of .55
I am thinking for low boost pressures the BSFC #s are closer to NA BSFC #'s
The generic BSFC of .6 to .65 that some efi injector calculators use is to be safe and very conservative.
I must remember that these formulas work when the correct numbers are input.
The injector manufacturers (and speed shops) would rather err on the big side than small.
An injector a bit too large will not melt a piston, however an injector a bit too small certainly will.
For the high boost engines when we richen the mixture to prevent detonation the BSFC numbers do get into the .6+ range.
I think we have got it Watson.
Using BSFC # of .55
Using BSFC # of .55
Using BSFC # of .55
Good stuff, thank you Perry.
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
