Gearbox question. Update 27/9/12
Looking to uprate my gearbox and I remember reading somewhere about IB5 bearings?! not sure if this is correct.
Have had a search on a few threads but im still not 100% what I'm looking for.
Can anyone shed any light?
The IB5 gearbox has a larger bearing and a stiffer case. Im using a mk5 diesel gearbox and to date its coping well with hard launches and heary driving but im not using the RS LSD which i suppose is helping it with prolonged life. Im runnng 248bhp 260lb torque and torque steer is a major issue so im going to try and use the LSD but im too not sure if the gearbox will last and might have to go MTX.
Parts you wll need:
Your old fork and bar
Breather pipe for the new gearbox
Gearbox http://www.ebay.co.uk/itm/FORD-ESCOR...item27bf557935
Speedo Gear http://www.ebay.co.uk/itm/FORD-ESCOR...item5ae1744e08
Gearbox bush http://www.ebay.co.uk/itm/Ford-Escor...item19b2cdf381
Clutch bearing http://www.clutch-specialists.co.uk/...VA-10-95-11-97
Hope this helps
Parts you wll need:
Hope this helps
Does the gearbox just bolt up to the series 2 cradle using the same mounts etc?
Juffer - What speeds do you get at around 6,000rpm in each gear, from memory mine is:
1st 40ish, 2nd 60, 3rd 90, 4th 120, and i don't know about 5th lol!
Also how does the lsd put more load on the box?
Although... i forget who i was speaking to, i think it was a gearbox recon company. They were firm believers that the open diff was very much a weak link in the ib5, and the lsd being a much stiffer unit meant less side loadings on bearings.... not sure how true that was but and lsd will load up the drive train more for sure, more grip = more load, same with uber sticky tyres.
Rob,
Rob,
How do you lower the rpm in 5th gear but maintain a high mph? Is it the final drive you change? The ratios on the mk5 derv box are ok for me but as you say rob 5th gear is a little high in the revs on the motorway.
I like the standard ratios... 2,800 rpm at 70 in 5th, combined with 60 in 2nd and 90 in 3rd makes a nice drive i think!
I see what you mean about the lsd now, i was looking at it the other way - wheelspin = more stress on the box so less spin = less load on it lol!
How easy does an IB5 fit?
I think this is also where im getting confused. Isn't it the final drive that will alter the revs? Has anybody got access to the ib5 diesel gear ratios? I have found a few ratios in the search for nearly everything else.
Escort RS turbo S1 ------------------- 3.15 1.91 1.27 0.95 0.76 4.27
Escort RS turbo S2* -------------------3.15 1.91 1.28 0.95 0.76 3.82
Escort RS1600i mk3 ------------------ 3.15 1.91 1.27 0.95 0.83 3.84
Escort XR3 5spd ---------------------- 3.15 1.91 1.28 0.95 0.76 3.84
Escort XR3i 5spd --------------------- 3.15 1.91 1.28 0.95 0.76 4.27
Fiesta 1.0 5spd mk2----------------- 3.58 2.04 1.35 0.95 0.76 4.29 (4spd 4.06 )
Fiesta 1.1 5spd mk2----------------- 3.58 2.04 1.35 0.95 0.76 3.84 (4spd 3.58 )
Fiesta 1.3 + 1.4 5spd mk2 --------- 3.58 2.04 1.35 0.95 0.76 3.84
Fiesta 1.6 diesel 84-89 -------------- 3.15 1.91 1.28 0.95 0.76 3.33
Fiesta XR2 mk2 ----------------------- 3.58 2.04 1.35 0.95 0.76 3.84
Fiesta XR2 mk2 (early?)-------------- 3.15 1.91 1.28 0.95 0.76 3.58
Fiesta RS Turbo* ---------------------- 3.15 1.91 1.28 0.95 0.76 3.82
Fiesta RS1800 mk3-------------------- 2.86 1.91 1.41 1.10 0.87 3.82
Fiesta 1.8 diesel 89-95 gearset B--- 3.58 1.93 1.28 0.95 0.76 3.82
Fiesta XR2i CVH mk3 ------------------ 3.15 1.91 1.28 0.95 0.76 4.069
some info
1.25/1.4 and 1.6 Zetec S Gear Ratios were found to be as following:
1st 3.58
2nd 1.93
3rd 1.28
4th 0.95
5th 0.76
The 1.7 Puma box however has a slightly taller 1st gear and a closer 3rd, 4th and 5th gear:
1st 3.15
2nd 1.93
3rd 1.41
4th 1.11
5th 0.88
The 1.6 Zetec S, has a 4.25 Final Drive Ratio
The 1.25/1.4, has a Final Drive Ratio of 4.27.
The 1.7 Puma has a Final Drive Ratio of 3.82
1st 3.58
2nd 1.93
3rd 1.28
4th 0.95
5th 0.76
1st 3.15
2nd 1.93
3rd 1.41
4th 1.11
5th 0.88
puma 1st and final, 1.6 zetec 2,3,4 and 5 would be close to a standard S2 box
Also i think the shaft in the IB5 would be bigger then a BC, have a puma gear set and S2 gears in the garage so i can check when i have time
chowfornow
14
05-01-2019 09:01 PM
TPM961
15-01-2018 10:50 AM
