Tubular manifolds
Tubular manifolds
Hey, was wondering what is (or if theres) any great benefits between a basic tubular manifold and the type that locates the turbo over the gearbox?
Any thoughts appreciated!
Cheers guys, after i posted started to think itd help cooling a bit! The engine is around 400hp on a standard manifold, just wanted a tubular due to the fact i think they look alot better
Belive so,, was still in it when i agreed to buy engine box etc,, think he was planning on selling the 16i shell, not sure tho, hopefully get car to him in next month or so
Yea mate complete set up,, itll be running haltech management,, keep meaning to start a build thread! I'll get one up at some stage
also if you use the exhaust manny which goes over the gearbox it will save your alternator LOL something which i had fried a month or so back but thats now been sorted
it would also be a good idea to remove the brake servo as you will find the turbo sitting close to the servo(not good)
Wye Valley Hardcore
I don't know huge amounts about optimum manifold design etc but generally an over the box type manifold will allow the car to run cooler moving the turbo away from the rad and giving more room at the front of the bay.
However, as a trade off you get higher Exhaust Gas Temps IIRC as the gas spends longer in the headers and will also loose low down torque and responce but gain more torque towards to top of the rev range. As with everything it will be a trade off and compromise.
Haha, yea i fried a few starter motors on the various cvh's ive had in it due to heat, untill i wrapped the downpipe and put a heatsheild on starter!
Wye Valley Hardcore
It Wasnt Me!
Well longer headers will help shift peak power up the rev range (longer inlet also needed to make the most of it)
Heat will be taken away from rad and IC as these are problems in rs turbos thats a good thing
You may lose thermal efficiency and will take longer to fill the longer mani before it spools the turbo (talking fractions here) so if you heat wrapped the manifold to keep the temperature up, that will help the turbo to spool up quicker again. (remember hot gasses expand more than cool ones, hot gass= more pressure = faster turbo spool up)
