wont start when its warm
right been having problems if i been out driving about and it warms up , when i go to park up say for ten mins and come back its becomes a right twat to start , i am wondering if it is to do with the fact the exhuast manifold gasket is blowing a bit ,
could it be losing the pressure a bit ? i have disconnected the cold start as i thought it was that. it does start eventually depends on how hot it was
any ideas?
any ideas?
sorted it i think , went out to try start it nothing yet spark from dizzy to plug nothing checked lead from coil to dizzy sparking took dizzy off it wasnt on properly so it had been rubbing on the contacts inside so put spare cap on properly and she fired up ,
right had a look , its not getting a spark from the coil and there is power coing to the coil , so does it look like the coil is the problem it starts fine after about 5 mins , what could it be ?
its will be either the fuel pump relay, dizzy or metering head
try tapping the top of the metering head when it wont start.
dizzys have a habit of breaking down when they get warm
You say no spark?
It could bee the hall sensor in the distributor breaking down when warm.
At cranking you should have +12v and a pulsed earth to the coil.
can be 2 problems :
1.) car dont want crank when is hot, starter motor problem, get a haet shield or/and new starter motor
2.) engine crank and starter turning but engine wont start (when warm), this is because metering head or fuel pump I really dont know for sure, but this problem can be "solved" if someone crank engine while you take off airbox and push the flap little down.
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
