rs turbo tappets...
rs turbo tappets...
getting a high pitched tapping coming form rocker cover, think its the tappets...
how much are these to buy and how hard to fit?
iv had i few escorts that have tapped and changed the tappets and it always turns out the same still tapping i would say cam, it's worth trying the tappets as you would want new if it is the cam
Theres no point just changing the tappets alone as after a few miles they will just start tapping again, new cam kit mate only way you will solve it
change the cam and tappets, they wear each other so if u replace them seperately and u will find the tapping will be back very quickly.
change both, the standard kit can be had for approx £100 from a motorfactors and is fine
JK12
33
26-04-2021 12:09 PM
