s2 fan problem
28-10-2007, 05:11 PM
s2 fan problem
my s2 fan wont come on,checked the fuses and there all fine,shorted the fan out and it works fine also,
what else can it be ? is there a relay for the fan that may be down ?
cheers
28-10-2007, 06:07 PM
yes mate there is a relay as you look at the fuse box its on the second row of relays(working away from the fuses)on the right hand side iirc
28-10-2007, 06:15 PM
You need a new fan switch
28-10-2007, 07:37 PM
as above if the fan works when u bridge the terminals that connect to the fan switch then the fan switch is ur problem
28-10-2007, 08:18 PM
wheres the fan switch on them mate ?
cheers
28-10-2007, 08:32 PM
on the thermostat housing under the top hose to the rad
29-10-2007, 04:19 PM
cheers mate thought that
29-10-2007, 05:34 PM
check wiring to plug as above changed miine to a lucas then
29-10-2007, 06:39 PM
#1 in Spelling Club
Re: check wiring to plug as above changed miine to a lucas t
Quote:
Originally Posted by margaret.brooks1@virgin.n
Random.
Chas
05-10-2015 07:13 PM
rs_jim
03-10-2015 11:37 AM
Russ Payne
25-09-2015 08:29 PM
mk1focus
Ford Fiesta
21-09-2015 05:46 PM
