Steering column question.
Old Sep 25, 2007 | 04:33 PM
JimmyBoy's Avatar
JimmyBoy
Default Steering column question.
When I pull off, my steering wheel judders a little bit. Also if I just sit there with the wheel in my hands, I get a little bit of play from side to side, would these problems be related to one another? does anyone know what the problem would be?
Thanks.
Old Sep 26, 2007 | 09:39 PM
vivien62's Avatar
vivien62
yeah hi,possibly all your steering column bushes are worn,if you know of its history and these have not been replaced then i would,relatively easy job,and ford still sell all the bushes,also check your sheer bolt on top of your column,to see if it is missing,this will make your instrument stalks move when your wheel lock is on giving the impression that the whole steering column is loose,for vibration check your discs,also another vague steering issue is that the wheel bearings could be worn,ok,thanx???
Old Sep 29, 2007 | 08:25 AM
NUTS RuS's Avatar
NUTS RuS
Check and replace the rod ends on the steering arms (bits on the end of the steering rack that bolts to the hub)
They are possibly worn
Old Sep 29, 2007 | 04:08 PM
JimmyBoy's Avatar
JimmyBoy
Thanks for the replies guys!
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
