Do most people use there S2s as an every day car
I dont use mine every day, and havent done for about nine years now.
I seriously couldnt bear it every day
I'd have to put some standard shocks back on if i did, and bin all the poly bushes...
mines used everyday and tbh it ain't that bad- EFi helps though
don't see any worse mpg than a v6 car and tbh with the konis teh ride ain't that bad, can't beat the heated front windscreen on the cold mornings either
I take it most people are running a safe spec - like 200bhp?
You lot must be doing something right if they are being used daily
Whats a good reliable engine spec then??
Thanks
Thanks
I used my series 2 everyday for nearly a yr and didn't miss a beat. Certainly didnt use my series 1 everyday....it was too good to drive. ha.
Reverted to cheap xr3i now, can do what i want with that!
they run better when used every day imo
Thanks
Thanks
mine is running around 280bhp
2.1 zvh on cossie management runnnig 28 psi.
and its only let me down when the head gasket went and the turbo went apart from that its great. or the fuel is not that good.
summer use only. it would be a sin to use it every day, and TBH i recently purchased a type r accord(shame on me!) which has totaly spoiled me! my girlfriend says she aint getin into the rs again
Mine used to be used everyday and had been for about 10 years. Then I got a runabout to save the RS getting messed up.
Saddly she hasn't turned a wheel since last November
