think i have a problem
Fleet Manager
noticed today that my car seems to be ideling abit high it used to idel at 1000prm now it about 1200rpm
its standard engine mfi s2 just stage 1 it was fine friday
also noticed my throttle bracket was loose and only had 1 bolt in, could this have affected it?
gonna stick another bolt in in the morning but i got a feeling the probs not going to go away
any ideas or advice on where to check etc most appriciated
Fleet Manager
right first thing first it was idling at 1400 not 1200 lol
i replaced and tightened it all the bolts....... no change
so i adjusted screw back so it idled an 1000, then when i turned it off and started it it was only idling at 700/800
so nipped it up a bit so it idled at 1100/1200 and it seems fine
i thought about the air leak but im sure when u have an air leak it makes it idle lower,
incidentally the blue and brown plugs were never connected on the back of the inlet so i connect the brown, dint seem to make any difference
it runs fine weather there connected or not
it was set up at grove about 3 months ago and they had to do some wiring because it would never idle or start from cold, and a excellent set up to
its been on the road for 3 weeks i changed the valve oil seals, (this is why the bracket was loose lol) do maybe its a settlement thing????
hopefully i susses it as i think the cable was i bit tight
any other info would be grate
also clean the auxiliary valve under the inlet where the 2 hard plastic pipes goes too
you could take this off and clean it internally and check to c if it still works
something like you out it in the freezer for about 10 mins and the hole inside should be closed
and when it warms up the hole will gradually open up almost fully
or the other way round ie open when cold and closed when hot
Fleet Manager
right i adjusted it before i went out so it was idling at 1100 been out for about an hour driving pretty hard and now its idling at 1350 again
i have noticed that the fast idle screw is out a bit should i let the throttle close totally???
dont rely wanna be adjust stuff as it me be masking a problem its been fine all the rest of the time ive owned it
When you get the fast idle is there still free play in the throttle cable?
To be honest it could be a number of things that could cause your problem. As you say you dont really want to start adjusting things, you would be better off taking it to someone with the correct equipment to check it for you.
Fleet Manager
nah it was in the normal position, ive put it back to how it was now,
i have been tinkering around it nearly all day gave it a water and oil change as its going on a rolling road tomorrow, it seems to be ok now idles at 1050 don't get higher or seem to drop maybe its ok now, sure we'll soon see
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
