where can i get low lowering springs?
i have a mk4 escort with -60 springs on but coz ive stripped the car out the rear end sits high about std height now!
i have avo coilovers but the rears still use conventional springs.
whats the lowest springs avaiable?
60mm is too low so be thankfull that the ride height is about where it should be. Lower than 40mm and you'll get worse handling and grip than you will by having the car higher
Cut 2 coils off them mate... that'll sort ya problem... even try 1 at a time until your happy...
If you dont wanna do that, then coilovers is the only way...
i dont want to cut coils as that makes a harder ride, just want lower ride.
it would be way too stiff if i cut it.
this is how it sits on -60
SMILER258
28-09-2015 09:04 AM
