Removing a dump valve
Old 06-05-2006 | 12:44 AM
Modder_J's Avatar
Modder_J
Default Removing a dump valve
Just had a trawl through the search results (got 400+ results) to try and find at least one post about how to remove the poo valve ... but I couldn't see any.
Does anyone have a rough guide on how to remove them ? Or is it just a case of taking it out, and plugging up the hole thats left behind ?
Old 06-05-2006 | 12:47 AM
rapidcossie's Avatar
rapidcossie
yep remove and plug mate
Old 06-05-2006 | 12:51 AM
rst_cabby's Avatar
rst_cabby
This is what you need ..... Have a look at the site
You can take it out & blank it with this.
You didn't say if it's in a boost hose or charge carrier pipe?
Old 06-05-2006 | 01:08 AM
SafeChav's Avatar
SafeChav
They're very nice but also expensive bungs
You will also need to remove the vacuum pipe which ran to it, air leaks are not good on an RST.
Old 06-05-2006 | 01:32 AM
Red16's Avatar
Red16
if youre dead lazy you could just remove the vacuum pipe as the dump valve will then never open and will act as if its not there.
better off plugging it tho
Old 06-05-2006 | 01:48 AM
SafeChav's Avatar
SafeChav
Don't forget there is the risk of the boost pressure overcoming that of the spring in the DV, meaning it will blow open on boost and leak.....
Old 06-05-2006 | 01:50 AM
DanRSturbo's Avatar
DanRSturbo
Remove, bung the dump vale hole, and also remove the pipe that goes from the dump vale to the inlet manifold feed.
Old 06-05-2006 | 02:07 AM
infinityMJD's Avatar
infinityMJD
forge motor sport in gloucester do the bungs dirt cheap! think most counties have a stockist, if not could get parts and post em for ppl, there about 5 mins from my house!
Old 06-05-2006 | 02:11 AM
SafeChav's Avatar
SafeChav
Are you from gloucester??????
Old 06-05-2006 | 02:12 AM
infinityMJD
yep, live in hucclecote if u no the area?
Old 06-05-2006 | 02:18 AM
SafeChav's Avatar
SafeChav
Im from cheltenham, hatherley, like.......10m mins away.......
Surprised u dont recognise the Orion in the siggy
Old 06-05-2006 | 02:20 AM
infinityMJD
been out of the scene for a long while, not been up the ring for years(ok that sounds dodgy to anyone not from round here)
only had the scort a matter of weeks so thats when i got on here and started postin, will have to keep an eye open for ya next time im up there
Old 06-05-2006 | 02:22 AM
SafeChav's Avatar
SafeChav
Nah that Orion is old skool mate, the girl i bought it off had it a good 6 years ago for about 3 years and she was out everywhere in it, she lived in churchdown. And i don't have it anymore either lol..
Old 06-05-2006 | 02:24 AM
infinityMJD
hmz, no idea then, should recognise it shows how good my memory is now
so if youve ditched the orion what u runnin now???
oh ye and as ure here im gunna hijack this post lol
elecy roof on a mk5, got power at switch, relay clicks in, and nada happens! any ideas
Old 06-05-2006 | 02:26 AM
SafeChav's Avatar
SafeChav
Better not mate start a new thread i don't want either of us to get in trouble
Old 06-05-2006 | 02:27 AM
infinityMJD
lool, good point is a thread about it on here somewhere allready, started it ages ago
Old 06-05-2006 | 02:29 AM
SafeChav's Avatar
SafeChav
Right.........this thread move there
https://passionford.com/forum/viewto...811496#2811496
Sorry about this post by the way
Old 06-05-2006 | 07:34 AM
HORNETS7's Avatar
HORNETS7
cheap way to bung up the hiole is get a medium size battery and a jubilee clip batterys are chrome on the end too allot cheaper and does the tricK!
Old 06-05-2006 | 08:19 AM
T28 RST's Avatar
T28 RST
Ok then
Cut the brush shaft and paint the end black, cost's 0 pence
Old 06-05-2006 | 10:00 AM
Modder_J's Avatar
Modder_J
It comes off a boost hose, think I might get the plug jobby.
More people say that the DV is worse on than off ... so might give it a try and see if theres anything different
Old 06-05-2006 | 11:05 AM
Red16's Avatar
Red16
very true, thats why its best off removing the bloody chava valve
Old 06-05-2006 | 12:08 PM
DanRSturbo's Avatar
DanRSturbo
"The Broom Valve"
Old 06-05-2006 | 12:56 PM
SafeChav's Avatar
SafeChav
Whats wrong with a chava valve
Old 07-07-2006 | 12:14 AM
Modder_J's Avatar
Modder_J
Thinking of getting a shiney poo valve plug from AS.
What happends to the pipe that goes from the top of the bus valve to the inlet manifold ? I read that it needs taking out, but what about the bit where it joins onto at the moment ?
Chatter here I come :P
Old 07-07-2006 | 08:19 AM
SafeChav's Avatar
SafeChav
Just block it off however best you can
Old 07-07-2006 | 11:40 AM
turboben's Avatar
turboben
got to love the broom handle and its free
Old 07-07-2006 | 03:57 PM
NIMRODS_RST's Avatar
NIMRODS_RST
MISSING MY RST!!
get rid!!!!!!!!!!
Fudgey
17-09-2015 01:06 PM
Si B
12-09-2015 06:49 AM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
hopper350
04-09-2015 12:53 AM
cossirob
03-09-2015 09:17 PM
Quick Reply: Removing a dump valve
