bosch fuel pump
bosch fuel pump
i have just bought a brand new standard pump for my s2 from ford, the previous owner of my car chopped off the terminals that go to the pump to fit an after market pump, does any one have these terminals lying about, they are like a female bullet connector but also have a large sleeve to protect against water, standard bullets are to small, i asked at my ford garage but they are no longer available any ideas please
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
look mate ,what i done was cut off my bullet connector ends,oh now i see,you have the pump that requires the female wires to attach, and your looking for the yellow and black sleeved ends,might have them,but cant look for a few days,had to cut mine off as my pump had screw fittings for loop connectors.
I may be able to get some off when im at the local scrappy for you
On this topic can some answer me if the RS pump is the same as the Bosch cossie pump, ive heard some people say it is and others it isn't
Audio specialist
i had a cossie one on my 88 s2 and remember going through all this when i went to buy one, as ford didnt have the original one.
Ah ok, if thats the case, no disrespect to yourself but that sounds like urban myth to me, i don't see why they would put a cossie one on so late down the line
I've tried looking on microcat but its not very clear? From what i can gather they are different but im still learning how to use microcat
Originally Posted by sime73
strange, i got some ring terminals and covers with mine and mine was a standard bosch one ?
thanks for replies , i may have sorted it, also if you go to bosch uk they direct you to there nearest agents, i found out today that genuine pump is available from them for £76.00 plus vat, all other KE bits are also available from them, also to safechav the pump is different to the cossie, bosch list all the different applications
KE is a Bosch system so thats why they have all the parts, more knowledge than the chimps at Ford aswell
taken from burton power catalogue
escort rs turbo bosch part no.0580254910 £87.50
cosworth saph bosch part no.0580254941 £129.99
they list the cosworth one as a upgrade for rst
JK12
33
26-04-2021 12:09 PM
