just need some advice on my brakes please
hello i have been thinking about my brakes at the mo. i have already done the conversion with the brackets to allow me to put the Sierra Sapphire RS Cosworth 2wd disc on. but i was just wondering if it was pos to put the Sierra Sapphire RS Cosworth Calipers on as well.
i have the brackets to allow me to put the standard erst calipers on with them disc just wounded if they would fit on with the brackets of or if they will fit straight on.
thanks for reading
thanks for reading
i use cossie 4x4 calipers matey...
they fit onto std holes... but u may need to make holes bigger to put bolts thru depedin on wot the calipers off...
u will probably need to put a 1mm washer/spacer between the bracket and caliper to centralise the caliper to disc properly...
think thats right... i did mine a while ago so cant remember exactly!
The Enigma
12-09-2015 10:12 PM
