Brake light problem
Old Apr 24, 2006 | 08:42 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Brake light problem
right to cut long story short i have no brake lights. Replaced bulbs, fuses, and the brake switch behind the pedal. Nothing. I then took a live feed from battery to the pedal switch and i get brake lights
so i guess it must be the realy in the fuse box???? Woul you all agree? If so could anyone please tell me which relay it is becaus ei honestly havnt got a clue
Old Apr 24, 2006 | 08:58 PM
SafeChav's Avatar
SafeChav
Alright mate, i can have a look on the wiring diagrams for you tomorrow. Usually things like that are in with interior lighing feeds etc, have you looked at all the fuses in fusebox yet?
Old Apr 24, 2006 | 09:00 PM
The Sludge's Avatar
The Sludge
garibaldi
yes i replaced all fuses for new ones th eother day. I have not replaced all relays as at this point i dont think i need to.
I have all fogs rear lights and bumper lights and indicators working to the rear.
Old Apr 24, 2006 | 09:16 PM
SafeChav's Avatar
SafeChav
If its a fuse you will have other things that don't work, there wont be a fuse just for the brake light wiring. More than likely tapped off one of the side light circuits.
I'll be able to tell you tomorrow
Old Apr 24, 2006 | 10:49 PM
The Sludge's Avatar
The Sludge
garibaldi
Old Apr 25, 2006 | 09:52 PM
The Sludge's Avatar
The Sludge
garibaldi
right i did a test wire from the live bat terminal direct to the brake light switch. It sent power to the lights and the work
I tested the fuse box and theres power there. I have therefor come to the conclusion that there has been a break in the circuit from the fuse box to the brake switch
what i have done temporarya s i nee to get it motd is run a piece of wire from the brake light pedal switch to the yellow ignition wire
it works
Old Apr 25, 2006 | 10:15 PM
SafeChav's Avatar
SafeChav
I forgot to look on them diagrams
I will tomorrow PROMISE
Old Apr 25, 2006 | 10:31 PM
The Sludge's Avatar
The Sludge
garibaldi
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
