repair or new scuttle
Old 30-04-2006, 09:58 PM
yorkshire ripper
yorkshire ripper's Avatar
Default repair or new scuttle
hi
this is the only bit of rot/rust on the windsreen scuttle, everywhere else is solid, would you advise cutting the rot out and welding in a good piece or fitting a new scuttle?
cheers
lee
Old 30-04-2006, 11:22 PM
mercury grey minter
mercury grey minter's Avatar
New scuttle ,their cheap and it,s pretty easy to do.
Old 30-04-2006, 11:31 PM
Mr S1
Don't ask - I don't know
Mr S1's Avatar
Change it mate - don't try and repair a hole of that magnitude.
Old 30-04-2006, 11:44 PM
SafeChav
SafeChav's Avatar
if you feel confident enough you can repair it then go for it, but u need to grind it back first cos theres still guna be a LOT of rot surrounding it.
For the time its going to take to repair you could probably fit a new one, although i thought the wings had to come off personally because the sides of the scuttle are welded to the inner wings?
Old 01-05-2006, 10:39 AM
CHRISP
CHRISP's Avatar
correct ....wings off , and screen out ....
Old 01-05-2006, 12:17 PM
Moondust_crust
Moondust_crust's Avatar
to be honest i would just repair it ,much less hassle than taking both wings off all you would have to do is cut out the rot and weld new piece back in, thats what i would do anywho
Old 01-05-2006, 09:37 PM
yorkshire ripper
well
ive made my mind up to cut it out and repair, if i fook it up i'll have a new scuttle fit
Old 01-05-2006, 11:17 PM
akito-man
akito-man's Avatar
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
do do do the back, do the back scuttle
roy chubby brown
or should it be
do do do the black, do the black scuttle,
Old 02-05-2006, 07:53 AM
mercury grey minter
For ease,i would cut a section out,about 4 inches in from each wing and just weld middle section in. Saves messing about with removing wings but you will still have 80% new scuttle
tankybaby66
06-02-2016 02:24 PM
gambo08
04-02-2016 10:49 PM
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
Quick Reply: repair or new scuttle
