1.6 turbo heads
mate wants a head for his fezz and i have several turbo heads hers just wondering with a skim will this go on as ithought the ports are smaller is this right or is it a no go??? thanks all
his is a 16 carb fed engine not turbo???????
Im sure they are the same head. Depends if his engine is lean burn though, ther majority went lean burn towards the end of the 80's run.
They have different combustion chambers, if you put a hemi head on a leanburn bottom end the compression will be massively out.
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
