fuel pump prob???
fuel pump prob???
my xr2 turbo wont start when its hot and been left for a while? starts fine from cold though? and it holds back at about 5000rpm under load?
just had this problem on my s2 changed nearly everything and after spending around £1000 it turned out to be the valve springs. Mine wouldnt pass 5000rpm either and it sounded like it was popping popcorn at 5000rpm dont know though if this could be the same problem has yours.
ive just had a kent cvh37 cam put in and it comes with double valve springs and anti pump lifters so doubt its that! if i use light throttle it holds back lightly just before it comes up on boost 2?
rite guys it tryed it again today and when it comes up on boost in second it pulls hard till 5000pm then holds back if i change gear quickly and still using full throttle it wont pick up at all so am i rite in thinking maybe fuel volume isnt enough???
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
