s1 fuel relay bridging
It Wasnt Me!
top one is | vertical in the middle and the other is bottom _ horizontal in middle also, cant mind what colours or whats top n bottom but u'll see what i mean when u look!
HTH
HTH
Originally Posted by JesseT
The think wires for the pump to run non-stop. I think they were red and black/red.
is there another way to get the relay to click when the ignition is turned on??
how can i make it work properly with a omex ecu installed
omex can controll a fuel pump but not when the tacho is in use because it only has 1 auxilery cable
I have replied in the other post for you...
cheers for the pointers lads
i was just bridging it to see if that was the pob with the car, which it isn,t
so relay getting plugged back in
bridged relay and pump is working fine, but when bdridging the relay i found that the power is 12v but when i try to start it ti drops to between 5-6volts,
im thinking that this drop would be enough to almost stop the pump from pumping enough fuel so that the engine is getting starved of fuel when i try to start it??
cheers
dave
cheers
dave
It looks like you will have to take action about your constantly lit battery light.
Check if the alternator is allright. With engine running you should have about 13.5 Volts. With engine off about 12 Volts.
i took the pink relay out and shoved in a standard relay and it works
turn key pump on wheee!!
turn key again pump off!!!
pm me if you want to buy a pink relay
listen to daz, i drove about for a while after doing this and my engine tuner said i was rather stupid. not only are u risking your own life its your passengers.
