S2 Starting problems
Old Mar 13, 2005 | 11:18 AM
Rob84's Avatar
Rob84
Default S2 Starting problems
Right, here goes
Should the fuel ignition relay have power from/to all 5 pins? At the moment, pins "31-" and "54-15" have no power at any position of the ignition key
should this be the case? if not, can some1 please point me in the direction to help sort it.
cheers
Old Mar 13, 2005 | 11:40 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
relay should have 1 permanent live,1 switched live from ign.when the ign switch is turned,the switched live operates the relay and makes a 3rd live to the fuel pump.check on the side of the relay as some have a diagram of the circuit on them.
Old Mar 13, 2005 | 11:50 AM
Rob84's Avatar
Rob84
i've since discovered, the thick red wire (power to pump) and thin red wire (negative to ecu) have no power
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
