Weird starting question............
Old Mar 24, 2005 | 08:03 PM
D200RST's Avatar
D200RST
Default Weird starting question............
My s2 has an unusual problem. when cold, it takes ages to start, you just keep turning it over for about 30 secs until it starts. when it does start (it always does), it runs brilliantly from cold and ticks over really well when both cold and warm. when hot, the car starts so quickly you hardly hear it turn over!!! quicker than my 2003 focus!!
the car runs fine all the time and everything is working the way it should. i do know the fuel pump has been uprated though but dont know what it is.
its not a prob cause it ALLWAYS starts and runs well all the time.
Old Mar 24, 2005 | 08:06 PM
CasperR's Avatar
CasperR
My car had problems starting, then I changed the fuel filter and it was ok.
Old Mar 24, 2005 | 10:27 PM
Dan's Avatar
Dan
Speak to RSKieron on here mate, sound like you've got the same problem as he had on his Series1, just needs the fuel pump relay changed
Uprated fuel pump might be slightly effecting something too mate, not sure really tho as i'm far from a mechanic! HTH
Old Mar 25, 2005 | 01:37 AM
RSKieron's Avatar
RSKieron
Mine wasn't exactly the same problem, but I do know that Mike in Yorkshire had the same problems as me and it's as follows.
On first cold starting the car, it fires up instantly then dies within 3 seconds. If you hold the revs on it will run lumpy for 30 seconds and then be fine.
It's a knackered fuel pump relay that causes it. Funnily enough, mine hasn't done it for a while! As soon as it does I am going to bridge the pins on the relay to test it, then go buy a new relay from the stealership.
Old Mar 25, 2005 | 08:37 AM
D200RST's Avatar
D200RST
no its not like that, it turns over without firing for 30 secs and then it suddenly sparks and starts immediately. when hot, it starts quicker than a speeding bullet. i aint got a clue what this could be! but im not gonna delve because its not really a problem, just slightly embarrassing when my mint escort takes 30secs to start!! lol
Old Mar 28, 2005 | 05:26 PM
addiction's Avatar
addiction
try disconnecting the cold start injector(just pull the plug off) i had the same problem and doin this cured it instantly!! even starts first time on a cold winter morning.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
