Starter Motor Heat Shield
Any one know of a place/website that sells them, as i am gettin a bit tired of stopping my engine then having to wait for the starter to cool down before the engine will start again??!!
do you mean the little heat sheild with the 2 clips that clip to the metal oil return pipe?? and the actual sheild is made of some kind of hard fibre with bako foil on it
I got a couple a few years ago, the material tends to disintergate around the clips, then fall off
ballin: then according to ford you should soon be start looking for a replacement starter
My starter went 1 year after my heat shield was destroyed
I've got mine wrapped in Thermotech heat proof Wrap and lock wire to keep it in place. Been on there a couple of years and is subject to an arse-load of heat and is so far.
Last starter motor lasted about 8 or 9 years with same treatment, but the original lasted about 5 minutes without any wrapping or the shield
So deffo fit something soon.
Cheers.
Cheers.
cossie09
10-09-2015 06:56 PM
