S1 and S2 fuel pump relays...
I can repair SOME of these relays depending on what the fault is.
If any of you have any old ones lying around and fancy having a spare I will repair them if you want.
Just fitted an alarm to my car, i noticed that the plastic on the bottom of the fuel pump relay is starting to melt, the car is still running ok. I replaced the terminals in the relay base on the red feed and red/black wire to the pump. You think it time for a new/repaired relay?
can anyone tell me where to locate the fuel pump relay please ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
i have owned a fiesta for 3 years and only just got a escort turbo but need to over ride the pump relay because im fiting omex
cheers mate any idea if i will be able to solder a wire across 2 of the terminals to keep the pump going with out engine turning because the omex wont control the pump when the tacho is in use
hopfuly this shouldnt efect the imobiliser
roll on the 2.1 zt!
roll on the 2.1 zt!
someonme fix one an send me it, im currently using a wire to bridge mine
Moonie, if it is still working then it is not soemthing that you can decide on to be honest. Usually the terminal is just getting hot which is what causes the melting. They do fail every so often. You could buy yourself a spare and keep it in the car then you have a "get out of jail free" card.
The standard S2 Escort relay uses pulses from the coil so this relay has NOTHING to do with the management (unlike the Escort S1 relay). As long as you have the green wire from the ignition coil negative to the relay then the relay will work as normal wether you have KE Jet or Pectel T10M or anythin at all. This relay is you SAFETY FUEL CUT OFF. If your management won't control a fuel pump relay then leave it in.
Originally Posted by mrviper
so basicly this relay is useless with a EFI system fitted ?
If your management you intend to fit can control the fuel pump, then wire it in with management. If the management that you intend to use will NOT control a fuel pump, then leave the fuel relay in, making sure you don't damage or remove the green wire from the relay itself, to where it joins onto the coil negative terminal.
Is that any clearer for you? It is basically a completely independant fuel pump control system that can still be utilised with an EFI system that may not have pump control....
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
