Cossie 4 pot calipers
Old 27-01-2012 | 05:13 PM
PhilCook's Avatar
PhilCook
Default Cossie 4 pot calipers
Quick question, do these need brakets/spacers to fit to the RS Turbo?
also, do I run Cossie discs or standard turbo discs?
Old 27-01-2012 | 06:33 PM
wedge07's Avatar
wedge07
I got the discs and calipers on mine, u need to drill out ur hub to 12mm as cossie calipers are this. Plus a couple of washers
Old 27-01-2012 | 06:39 PM
xr_craig's Avatar
xr_craig
Not 100% but i think you will need machine 5mm of the caliper lug/hub to get the 4 pots to fit.
Old 27-01-2012 | 07:31 PM
luke19790_3's Avatar
luke19790_3
2wd calipers are different to 4wd calipers?
2wd (4pot) needs 4mm machining off the lug.
st170 discs and mondeo calipers are a good cheap mod
Old 27-01-2012 | 07:48 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
As allready been said I machined 4mm off caliper faces and drilled and tapped hubs you need 283mm disks think that's what I used. Do a search mate its been covered a few times I think hope this helps cheers nick.
Old 28-01-2012 | 12:24 AM
PhilCook's Avatar
PhilCook
Cheers guys.
Didnt see the sticky at the top of the page, its also not mega clear, but will grab the 2wd calipers off my mate and order some discs and pads, then go from there
Old 29-01-2012 | 07:18 PM
gtit's Avatar
gtit
beavers spot on fitted mine last week just needing bled, looks ace! i got goodrige hoses made up with banjo ends on them tidy,
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Cossie 4 pot calipers
