zetec breather setup
hello can anyone tell me what breather setup up they have on there zetec turbo or show me a picture that would be great thank you. here is a picture of my engine if you can point me in right area
you also have to pipe the oil return from breather back to sump , remember and put it below the oil level or engine will just breath from that pipe aswell and breather will fill with oil
heres a couple of pics of what i had
i also had catch tank after breather then to atmosphere , you can see top of it mounted on chassis leg , i also modified the front block breather to accept 16mm hose instead of 10mm
there is'nt one at back of block mate , only front of block and rocker cover
as for oil return to sump you will have to get your sump modded for this
pm me your number if you want a quick chat about it
cheers
john
i didnt look on the sump to see if anything was there ill have another look tonight. i do welding anyway so all ill have to do is drill hole an weld a bit of tube. will anywhere on sump do cheers
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
