Rebuilding metering unit
I need to have a go at reconditioning my metering unit iv brought the gasket and washers kit etc is there anything else I myt need or anything to look out for when I attempt it as I can't realy afford £420 to get it done by some1 else any tips or things to look out for
CheeRS
CheeRS
B4 I took the car off the road to paint engine bay and new engine goin in when the mixture was set it would only last a couple of days then would go all to shit the revs where up and down also missed on full boost and held Bk but stunk of fuel on tick over just didn't run right
lol yeah there a pain in the arse but cant afford to go efi or aftermarket management so trying to make do wiv what iv got maybe a strip down clean and new gaskets etc myt b enough or save £420 and send it off to be reconditioned
Will it ever end !!!!!!!
Here are some pics of whats inside when you take it apart to give you an idea
![Name: Picture001-2.jpg
Size: 205.5 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139354d1501884623-rebuilding-metering-unit-picture001-2.jpg)
![Name: Picture006.jpg
Size: 78.7 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139355d1501884623-rebuilding-metering-unit-picture006.jpg)
![Name: Picture007.jpg
Size: 134.2 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139356d1501884623-rebuilding-metering-unit-picture007.jpg)
Now i did take it apart but other than just cleaning it inside with some thinners I did not touch a thing. It was easy to mask to repaint and the only new item is the gasket so with a bit of powdercoating and paint it ended up with this. All i would say is take apart as little as possible.
![Name: Picture001-3.jpg
Size: 129.0 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139357d1501884623-rebuilding-metering-unit-picture001-3.jpg)
![Name: Picture003-4.jpg
Size: 116.6 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139358d1501884623-rebuilding-metering-unit-picture003-4.jpg)
![Name: Picture002-4.jpg
Size: 105.9 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139359d1501884623-rebuilding-metering-unit-picture002-4.jpg)
Cheers m8 I'll give it ago did it wrk better wiv what you done iv been told there's a o ring by the mixture screw that breaks and the diaphram leeks or something like that
Mc5506
05-10-2015 09:57 PM
Steve Escos
01-10-2015 06:57 AM
