Speedo sensor removal
I've just got rid of all that too, it was easy to put back, but I removed it after I had removed all the abs crap, so can't think if it was easy or not,
Why you removing it?
no, it stays still the inside turns.
to get to the drive you have to remove the speed sensor then there is a roll pin through the diff housing, this needs removing in order to get the bit that the speed senor attaches to out of the gearbox, the drive is below that
Got it mate, fitted a new cable and the speedo still doesnt work, is it likely to be the drive thats fucked or the clocks?
Cheers for the help, Paul
I would use side cutters to squeeze the pin whilst levering against the gearbox casing.
Don't squeeze so hard that you cut the pin.
Or you could try a good pair of vice grips
DixieTheKid
11
06-06-2020 11:20 AM
Fudgey
17-09-2015 01:06 PM
Dr. Ickxs
15-09-2015 10:15 PM
Si B
12-09-2015 06:49 AM
