New metering unit
New metering unit
Hi got a quote 2day 4 a brand new metering unit direct from Bosch in Germany £1500 that's wiv out the vat added very expensive myt just have a go at reconditioning mine i think
Why does everyone go to YWK when all he does is get from FORD and put a mark up on items ??????????????????????????????????????
I refurbed mine myself - pretty easy to do really.
Also did my throttle body and manifold as well - again easy enough.
Did u have problems wiv your metering unit b4 you reconed it And after was it all sorted I took mine apart the weekend cleaned the inside the bottom half did you clean all inside the top bit if so how and what wiv and did you strip the top half completely
I kept stripping to a minimumn - these are very temperamental so did not want to remove anything i didnt need to - to clean it i used thinners mainly as this will break down anything that shouldnt be there and finally just some brake cleaner then an airline to ensure nothing clogged or blocked where it shouldnt be.
It worked fine before and after stripping and rebuilding it should be fine after - i did not touch the top distribution block at all other than cleaning the outside of it.
Steve Escos
01-10-2015 06:57 AM
