dodgy starter?
Sometimes wen i go to turn on n i get nothing, just fuel pump kicks in
I was thinking starter motor, or wire to it is dodgy?
Anybody got an idea?
Theres a single wire on the back of the starter like a spade connector, make sure wire isny dodgy. It's for the solenoid to fire the pinion gear out to mesh with ring gear I think. I had this wire come off one day!
heck if the starter is drawing power when you try to crank (lights in dash should fade) if it does then it can be a number of things, but the starter needs to come out. Hope this was helpfull
Ill try these out cheers, its weird drove about yesterday then after i turned off i checked car again straight away n i wouldnt fire up, it turned over like it had a flat battery, came to it later on n no probs at all.
My dad said he had same prob on his, turned out something was missing off car, but he cant remember wat it was, he said it was only a cheap part needed?
Any ideas?
Any ideas?
With that wire off mine never even turned over. Heat off the downpipe can kill starters so if you have ruled everything else out, i.e loose wires, dodgy earth straps then id change the starter.
Any ideas?
Any ideas?
I only just got on it lol, work nights n sleep all weekdays haha, friday n weekend to play with cars ![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
Now my bonnet latch is stuck, n cant get it open?! Any ideas on how to get in?
Tried that way but its an xr3i so fans on inside n in way :-(. Only had car a week so tryin get all the little faults sorted.
Major prob is my insurance want 6 pics of car n one is engine bay!
Not avin alot of luck ere am i
I have an xr3 cabrio with the same problems! You CAN reach up and past the fan to open the bonnet. Just make sure the engine aint HOT I burnt my arm! but needs must I was running out of water in the euston underpass!! Good luck and there are new bonnet release cables gen ford on ebay for when you get it open. Only a 10 min job to change
