Pressure in header tank
Old 12-05-2012, 12:58 PM
Mats1985
Mats1985's Avatar
Default Pressure in header tank
Hi every time I take the s2 Rs out when I stop anywhere there's always a build up of pressure in the header tank let the cap off and hear bubbling in the system and water+air comes out of the header tank it's just been built new water pump and thermostat any ideas
Old 12-05-2012, 03:49 PM
simonmcf
simonmcf's Avatar
Not sure but possible air lock or head gasket maybe?
Old 12-05-2012, 04:00 PM
jonny s2
jonny s2's Avatar
as above head gasket, air lock, or poss rad??
Mats1985
Mats1985's Avatar
Maybe but if it's air lock I'm sure it would have cleared by now the headgasket is new aswell and no oil/water mixing etc this myt sound weird but the bolts on the thermostat needed tightening the other day and 2day I could get a quarter of a turn on each 1 so thinking thery myt b wrking loose and drawing in air maybe
Old 12-05-2012, 04:08 PM
jonny s2
jonny s2's Avatar
possibly mate, if its bubbling it could be early signs of the gasket tho, what type of gasket did you use?
Old 12-05-2012, 04:13 PM
Mats1985
Mats1985's Avatar
Payne headgasket normal driving around temp never goes above m on the gauge but 2day in traffic went to o on gauge but was a warm day 2day it's got alloy rads turbo cooler and twin fans
Old 12-05-2012, 04:26 PM
fiesta23
fiesta23's Avatar
has it been left to cool before being switched off ? when its immediately switched off the water will stop circulating round and a hot turbo will boil the water and expand causing the bubbling.
might be the case or something more serious
Old 12-05-2012, 04:45 PM
Fraggle...
On a tangent
Fraggle...'s Avatar
Sure the thermostat itself is alright?
is the coolant definately flowing/pumping round the system?
Heaters doing both as they should?
Old 12-05-2012, 05:00 PM
Mats1985
Mats1985's Avatar
If ya take of the cap when it's running the water flows proply just when it turns off it bubbles and pressure
Old 12-05-2012, 05:13 PM
Fraggle...
On a tangent
Fraggle...'s Avatar
is it a metal header tank or plastic?
I had a bailey one, kept doing this, changed the cap and all was well, either way might be worth checking it to be sure.
Check what i said above re stat..and perhaps give it a bleed again to be sure, if still doing it then its looking like a possible HG prob.
Old 12-05-2012, 05:28 PM
Mats1985
Mats1985's Avatar
I did have a standard plastic 1 and changed it for a second hand Bailey where can ya get new caps for 1 I did email Bailey themselves but herd nothing back also u can only feel the bubbling in the top hose when it's turned off if that makes sense
Old 12-05-2012, 05:43 PM
Fraggle...
On a tangent
Fraggle...'s Avatar
I got mine direct from them, cost Ł17:54 back in 09!!
Its kept under my bed for safety, not risking it out in public at that price
Like has been suggested above fella, could be the turbo is boiling the coolant up, HG, stat, Matrix blocked, a sensor down..........................
If your water/freeze mix are good and to spec and everything else is working as should eg fans coming in early enough..................
then its sounding praps the worst case of a maybe a crack somewhere..
Or simply not enough AIR getting to the motor/rad to generally cool the ambience of the bay..thus heatsoak into the motor/coolant.
Old 12-05-2012, 06:02 PM
Mats1985
Mats1985's Avatar
Ok I'll check over things 2moz try get a cap from Bailey and see how I get on cheers for advise and help if I find a solution will share it cheers
Old 12-05-2012, 06:09 PM
Fraggle...
On a tangent
Fraggle...'s Avatar
Best thing you can do fella, check EVERYTHING 1st and rule ALL the simple's out to be sure.
Best of British
Old 19-05-2012, 03:16 PM
Mats1985
Mats1985's Avatar
had a play today new gasket on thermotst housing lock tight on bolts checked all pipes where tight went for a drive pulled up wiv car running cap of no pressure what so ever but i turned the engine of wiv cap still off and wait around 2-3 mins then bubbles start in top hose and lasts for around 5mins then settles been for a few journeys and same every time cant b headgasket else the pressure would b there all the time surly
any ideas
Old 20-05-2012, 05:34 PM
tasos77
rs turbo from Greece...
tasos77's Avatar
try to bypass the heater matrix. mine use to do the same and the reason was a blocked matrix...
Old 20-05-2012, 05:47 PM
Mats1985
Mats1985's Avatar
Yeah I'll give it ago or buy a new 1 there only Ł30ish it's realy weird no pressure at all when it's running but as soon as you turn it off it starts the bubble and pressurise although it's running slightly hotter than It used to on the gauge especially if stop in traffic it starts to climb realy can't make out what's goin on
Old 20-05-2012, 06:50 PM
Marc D
Marc D's Avatar
do a compression test to check the head gasket
Old 20-05-2012, 06:59 PM
Mats1985
Mats1985's Avatar
Guna do compression test and sniff test to try rule out headgasket not sure what else to try even my bro the mechanic has never known it or figure out what it could b doin my head in
Old 20-05-2012, 08:02 PM
mgtkr1
mgtkr1's Avatar
probably the header tank cap. i noticed mine used to bubble and sptted that someone had tried to get a better seal with silicone.
i still have that same cap but recently changed to an 82 thermostat and once id got the air out the system it hasnt done it. my t'stat housing bolts were loose aswell wich allows air into the system and quickly pressurises.
a dab of silicone over the head bolts is an added safetly measure along with loctite. a trick from racing were lockwire is unable to be implemented due to access.
are your fans right up front or aft intercooler (between ic and rad) or behind the rad? atm my fan is in front of the ic and is nigh on useless. going to mount a slim one between rad &/i/cooler
Old 20-05-2012, 08:17 PM
Mats1985
Mats1985's Avatar
Iv been trying to get hold of Bailey motorsport for new cap no luck as yet I'm thinking of removing the thermostat iv got twin fans on it there connected to the alloy rad in front of rad but behind the inter cooler
Old 21-05-2012, 12:14 AM
AstoN_B
An eye for detail...
AstoN_B's Avatar
Are you sure it isn't just the turbo siphon cooling?
I've heard before that when you switch off the turbo boils the water inside it which causes enough pressure in the top water connection to force cooler water into the bottom of it creating its own flow of cooler water. if plumbed in correctly its supposedly designed to cool the turbo until it reaches a more comfortable (non boiling) temperature, without the need for a pump or anything.
Old 21-05-2012, 06:34 AM
Mats1985
Mats1985's Avatar
Some1 else mentioned that and some cossies do it but I no a couple of people wiv Rs turbos and none of there's do it although mine is tge only 1 wiv a turbo cooler but recently it's started to run abit hotter than it used to
Old 21-05-2012, 07:28 AM
Fordmad!
Fordmad!'s Avatar
Head could be craked
Old 21-05-2012, 08:10 AM
Mats1985
Mats1985's Avatar
I had the head pressure tested b4 I put it 2geather
Old 21-05-2012, 02:48 PM
s2turbsZVH
Will it ever end !!!!!!!
s2turbsZVH's Avatar
Found you a cap anyway
http://www.ebay.co.uk/itm/Bailey-Hea...item35bc6ba07e
Old 21-05-2012, 03:34 PM
Mats1985
Mats1985's Avatar
Lol iv just ordered 1 from Bailey Ł21 deliverd expensive
Old 22-05-2012, 09:14 PM
Mats1985
Mats1985's Avatar
Thermostat removed new header tank cap still the same
Old 22-05-2012, 09:21 PM
mgtkr1
mgtkr1's Avatar
assuming the t'stat is working, removing is not a good idea as it regulates flow and controls the coolant temp better than just allowing it to circulate regardless of temp. also takes ages to warm up.
id go round all the hose clamps again. do your mates with rst' have std header tanks or the fabbed alloy ones. im srarting to see a pattern where cars with alloy header tanks seem to bubble. still, could be a stubborn air pocket.
id be suprised if its a hg.
Old 22-05-2012, 10:26 PM
Mats1985
Mats1985's Avatar
I hear what ya saying bout thermostat it gets hot quick and runs hotter than it used to I did have a standard header tank on it and did the same then that's why I thought I'd change it
Aswell the amount of times iv bled the system and been out in it I would have thought the air lock would have cleared
Sniff test and pressure test 2moz nyt to see if anything comes of it
Old 23-05-2012, 08:24 PM
Mats1985
Mats1985's Avatar
Pressure test 2nyt my pro alloy rad is leaking very slightly bottom Corner
Old 23-05-2012, 09:17 PM
mgtkr1
mgtkr1's Avatar
how much is it leaking? just a weep?
Old 23-05-2012, 09:33 PM
Mats1985
Mats1985's Avatar
Yeah weeping drip every 5-10 seconds or so no other leaks anywhere also guna replace matrix as heaters are crap hardly any heat
Old 08-06-2012, 11:24 AM
BRAM
BRAM's Avatar
Have you had a look inside your thermostat housing to see if it still has the plastic float that is there to help with air in the system?
My brother has been having similar problems and found a thread on this site somwhere explaining about the float, when he took his housing off his float was missing, so he bought a new housing from ford and the car seems to be a lot better now.
I'm going out now but when i get back i will try to find the thread and post a link up!!!!
Old 08-06-2012, 12:30 PM
Mats1985
Mats1985's Avatar
Oh ryt never herd of that iv got 2 thermostat housings and there's nothing in them iv changed the rad had new matrix removed thermostat blasted all the water ways including turbo cooler and still the same
Old 08-06-2012, 03:15 PM
rsturbonutter
rsturbonutter's Avatar
I had this problem when I fitted my front mount. I think it is the fact that the rad is restricted to cooling due to the decrease in air flow. I changed my head gasket which had only done 400 miles, thermo, fan virtually everything and it still done it. One day just out of curiousity I removed my front mount and put a standard cooler on and suprise suprise no more bubbling sound. Not saying it is this with yours mate but if you got a standard cooler hanging around give it a try can't hurt
rsturbonutter
I will add that my car is a fiesta rs not an escort but the fundamentals are the same
Old 09-06-2012, 08:56 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
2 Things i noticed while reading.
First is that you say you have had a gasket fitted and the engine has been apart at some point recently. So the question is has it been setup of checked since.
The second is that if you have a small air leak on any of the water system it will cause the water to boil as the boiling point will be dropped to the std 100degree. If there is no leaks then the water wont boil till 110degree. So the point here is that if you have any leak however small it will cause the water system to run hot and not be able to cool down easy.
I advise to change the rad or repair if possible.
Then have a setup and road tune.
After this there should be no issues going by what you have said regarding new gasket etc.
Old 09-06-2012, 02:33 PM
Mats1985
Mats1985's Avatar
Iv changed the rad had a pressure test and no leaks anymore changed the matrix and all still the same after a jurney turn engine off and pressure there it dosnt run hot anymore just pressure when everything is turned off
Old 10-06-2012, 10:22 AM
AstoN_B
AstoN_B's Avatar
There is usually a small amount of pressure in every cooling system which serves the purpose of raising the boiling point as Jano said.
It's the heat which cause the pressure to rise in the first place, so until it cools down the pressure won't go anywhere, unless you take the cap off expansion tank. This is a bad idea if its still red hot!!
Quick Reply: Pressure in header tank
