Possible air leak
Possible air leak
Start up the rs and the boost gauge is fine as soon as it warms up and comes off choke on idle when it's in vacuum it won't stay still Car is idling at 1000 rpm according to rev counter
Lewis
Lewis
sounds like an air leak or dud tps? do the tps chech making sure it clicks before checking all hoses/vaccum and oil fillers/breathers.
3dr Cosworth owner
Have you recently fitted a dump valve by any the wrng one as escortchance? If so id say it is the wrong one. Escirt turbo's require a specific one. If not Possibly air leak or if you have a diaphram dump valve fitted it could have split
Lewis
the tps is on the throttle body. its a black box type shape and when you move the throttle linkage by hand it should click. dump valves can cause all sorts of bother esp if the wrong type is used.
i took it as rev counter ''hunting'' at idle.
what would cause the boost gauge to fluctuate? knackered boost gauge or trapped vac pipe?
ah. split in vac from somewhere up to boost gauge. start at the manifold, tee piece up to boost gauge. can be a bastard to trace. just replace with some new pipe and see if the problem persists
cheers lads! was going to just let jano have a look when it goes up there but if its easy as that then were do it! can i use silicone hose for the vac pipes? if so what diameter and what diameter is boost gauge piping i cant remember?
Lewis
Lewis
3mm id rings a bell if its silicone. also check the tee piece. cheap ones are more brittle and break easily owed to the low nylon/high plastic material
im going to forge motorsport this week at some point so il take some hoses, and t pieces over and get them to sort me out! glad forge is local to me haha
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
