Safe boost pressure on S1 turbo
As above really, just wondering what is a same boost pressure to be running day to day? Its currently runnning 10 psi but it had a bleed valve on it just wondering if i could up the boost by a few psi without causing any damage. What pressure are you guys running? The engine is healthy and recently rebuilt showing 170 psi on all cylinders.
Thanks in advanced
Thanks in advanced
there is no answer to this question. If you're already on the edge of the fueling then you're already at the limit. You need to get it turned up then have the fueling adjusted to suit by someone who has a wide band and knows what they are doing.
Matt Baxter
16-09-2015 08:30 PM
gchristophi
31-08-2015 10:36 PM
CrOwSoN15
18
22-08-2015 10:24 PM
