if it's a 1.8 you can use a standard ford cvh job. If it's a 2.0 or 2.1 have your head welded and machined to accept a focus rs gasket like mine. ONLY way to do it IMO. Felpro are for N/A American cvh and aren't suited for high boost.
cometic make a cvh style head gasket but useing an 86mm bore so perfict for 2.1 zvh IMO
For £100 you can have the machine work done to the head to accept a Zetec gasket and £20 for a Focus RS gasket though. The commetic is £90-100 plus the block AND head have to be machined to a 0.020mm tolerence or something otherwise it will fail. So it would actaully work out cheaper to go down the Zetec route anyway.
had a felpro and after a month i had oil in the water just from running car in so scrapped that and got a 86mm cometic one of ebay, never had any proplems since
