wineing noise
Old 20-06-2009 | 10:35 AM
RS CR41G's Avatar
RS CR41G
Default wineing noise
the last couple of days i have bin out in my rs turbo cab.an there is a bad wineing noise,it dosent sound like its from the gearbox an the gear changes am mint,ive put a new clutch in it an new gearbox oil,the timing is abit out could it be this? it seems like the noise is underneath the car by the handbrake! any ideas would be great,or any body nows wot it is would be better.thanks craig
Old 20-06-2009 | 01:45 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
wheels bearings?
Old 20-06-2009 | 01:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
The wife?
Old 20-06-2009 | 02:15 PM
jonny s2's Avatar
jonny s2
handbrake cable scaping on the floor?
Old 21-06-2009 | 11:30 AM
RS CR41G's Avatar
RS CR41G
thanks guys,but its none of these! the engine is fresh rebuilt so its not that, jus hope its not the gearbox!
Old 21-06-2009 | 11:31 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Originally Posted by Stu @ M Developments
The wife?
dam you beat me to it
Old 21-06-2009 | 03:06 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
it could be the clutch release bearing, have ya got abs on ya cab
Old 21-06-2009 | 07:18 PM
Matt-Turbo's Avatar
Matt-Turbo
Not bein smart or nothing but did you upgrade the fuel pump and your only noticing the louder noise now?
Old 22-06-2009 | 07:28 AM
RS CR41G's Avatar
RS CR41G
i have taken the abs off but it was doin this noise when abs was on,the clutch release bearing is new but it could be that,but it sounds like its not from gearbox.but sayin that the noise comes when u change gear and drive along so it is a wineing noise.the fuel pump is still the same one.i think im guna av 2 take it sum where jus hope it a the gearbox because the car needs setting up on rolling road.thanks guys for the help
Old 22-06-2009 | 03:35 PM
gingerturbo
you could try and old trick and get a long screwdriver and touch the tip on the bell housing while the engine is running get someone to push the cluh in and out and listen through the screw driver for the squeeking, also check the tin plate on the back of the disks
gingeRS
17
02-10-2015 09:42 AM
Botts
22-09-2015 02:04 PM
pieterjan
Ford Focus RS
17-09-2015 06:17 PM
rsturbo27
05-09-2015 05:08 PM
Quick Reply: wineing noise
