valves
Old Jun 15, 2009 | 04:52 PM
andy130's Avatar
andy130
Default valves
does this sound right to you?
outlet valves
this is how far the valve comes out.
1.
5mm/6mm
2.
5mm/6mm
3.
5mm/6mm
4.
5mm
the inlet valves
1.
5mm
2.
5mm
3.
4mm
4.
4mm
they might be out about 1mm maybe notthing more then that!
its got a piper t2 cam in it.
cheers andy
Old Jun 15, 2009 | 04:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If thats how far they come out when at full lift then something is very wrong!! Sound like you have munched a cam
Old Jun 15, 2009 | 05:01 PM
andy130's Avatar
andy130
fuck
Old Jun 15, 2009 | 05:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I'm assuming you mean how far they come away from the valve seats in the face of the head yeah?
Old Jun 15, 2009 | 05:07 PM
andy130's Avatar
andy130
yeah mate?
the post above is wrong
Old Jun 15, 2009 | 05:55 PM
mark2's Avatar
mark2
+1
remove the cam time and check lobes with a digital vernier but sure that much wear you will notice or on the other hand when you measured the fulllift from valve side was there more carbon build up on those with the lower reading
mark2
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
