Does anybody know the spec?
stg1 is just a 360 bearing stg2 360+2wheel drive cossie comp wheel and a .48 housing and stg3 same with a 4x4 cossie comp wheel on it.
you got 360 bearing ,then comp wheel's 4x4 cossy or 2wd cossy then you have the .49turbine housing and cut back turbine wheel .then you can have a t34 with the .49
turbine or .63
turbine or .63
YES I KNOW I CANT SPELL
