erst running problems
Old Jun 23, 2009 | 10:54 PM
tbs's Avatar
tbs
Default erst running problems
hi just had top end rebuild and car runs fine on idle alittle high i would say if i rev it some times it cuts out not all the time though. or it seems like its gonna and starts to idle again some times when i boot it and come to a stop at a junction it seems like its gonna cut out and some times it does also when i put my foot down the boost is a little hesitant. ive changed the metering unit no different and also checked that the boost wasnt to high just cant work out what it can be? or does it just need a simple set up thanks if any one can help as im getting realy sick off it.
Old Jun 24, 2009 | 07:03 AM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
m8 - anything like this is best left to a tuner as it could be a number of things - timing,fuelling,tps out etc etc.
Take it to a tuner as it would cost a lot less than you buying parts to replace.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Ellsa
Aug 9, 2015 07:03 PM
