Oil coming from exhaust manifold gasket?
Old 15-06-2009 | 10:08 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Oil coming from exhaust manifold gasket?
Basically it wasn't doing this the last time I had it running in the barn and is now. The car has done 0 miles.
I started the car needed throttle to start, loads of black smoke out of exhaust and oil coming out of the manifold.
Old 15-06-2009 | 10:42 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
its either coming from the turbo or fooked piston rings i would say
Old 15-06-2009 | 10:55 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
It's not running down from your (non genuine?) rocker cover gasket, is it?
Old 15-06-2009 | 10:58 PM
muz's Avatar
muz
Wye Valley Hardcore
I wish it was Deffo coming out between the gasket and the manifold. Think I need to do a compression test to hopefully rule out piston rings. I'd rather replace the turbo than the rings
Old 15-06-2009 | 11:24 PM
mark2's Avatar
mark2
hi
a comp test might be a bit misleading due to the fact with oil in the bores will act like a wet comp test and show a good comp as the oil will seal a bit of ring blow by if you follow me , might be a head/sump off time and pistons out to inspect the rings properly
drop the boost pipes off and look for oil in them as it might be oil seals on the turbo you will have a bit of oil in them but very very little is normal if you take the bottom boost hose off and poke somethink in the i/c to see if there is oil in there or take i/c out completely
whilst head/sump is open and the rings are gone the jobs half done with regards striping the engine for new rings
hope all is well thou
mark
Old 16-06-2009 | 01:59 PM
muz's Avatar
muz
Wye Valley Hardcore
I really hope its the turbo I dont fancy taking the engine to bits again. I'll check for oil in the boost pipes tomorrow.
Old 16-06-2009 | 08:01 PM
mark2's Avatar
mark2
good luck
rings would be cheaper than a new turbo thou lol if i had to pick at wot was wrong i would say turbo as you said its sat for a while in the barn and gravity dont go up so if it was rings the oil that was there when it last run surely would of drained down
mark2
Old 16-06-2009 | 08:43 PM
muz's Avatar
muz
Wye Valley Hardcore
LOL I know ring would be cheaper but the engine has been in and out 3 times and the car hasn't seen the road LOL and there's play in the turbo shaft so excuse to re build it anyway. Car didn't smoke etc when it was on the road so doubt rings have gone just being sat there whereas turbo seals could go anytime.
Old 16-06-2009 | 09:20 PM
mark2's Avatar
mark2
dont know how long it has sat but could be the control ring stuck ? does it leak from all the ex/ports or just one ?
every thought might just need a good run to clear it out
realy hope its a simple fix for you
mark2
Old 16-06-2009 | 09:26 PM
mark2's Avatar
mark2
i must be a twat so
if you have no exhaust manifold gases leaking how does oil come out the manifold, have you checked rocker gasket ( sure you have thou ) but double checked it
sorry to throw up solutions but just like to help
mark2
Old 16-06-2009 | 11:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmmm i'm thinking rings...... otherwise the oil from the turbo would have to come back up the manifold and force it's way out against exhaust gas presure??
Old 16-06-2009 | 11:19 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Have you tasted the 'oil' thats coming out of the manifold!? Are you sure its oil & not carbon mixed with fuel? Reason I ask is that if you are seeing black smoke out of the exhaust then that would suggest overfuelling.
If it was that much oil coming out - you should be getting plumes of blue smoke. Also bear in mind that the manifold is before the turbo - so would be doubtful it would be the turbo causing the issue.
Has your oil level dropped at all?
Old 17-06-2009 | 09:41 AM
muz's Avatar
muz
Wye Valley Hardcore
Actaully lee that might well be the case! I'd been working on it all day and it was late so was too tired to even think that.
Think I must have loosened the manifold at soem point as well as it was all tourqued up
I'll go put some hours in now and let you know that it is
Old 17-06-2009 | 10:44 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've had a similar prob on my xr2 turbo zvh, firstly i had serious overfuelling which mixed with carbon deposits casing the same sort of effect as i changed to efi on MS.
but that was compounded by my turbo dying at the same time.
Old 18-06-2009 | 03:44 PM
muz's Avatar
muz
Wye Valley Hardcore
It is petrol Needs some new leads.
Old 18-06-2009 | 08:48 PM
mark2's Avatar
mark2
hats off to you well called
i did think turbo but i am a numpty
mark2
Old 18-06-2009 | 10:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah well spotted!
The black smoke's the give away, but fuck me that must be a lot of overfuelling!!
Old 18-06-2009 | 10:44 PM
mark2's Avatar
mark2
Originally Posted by Karlos G
Yeah well spotted!
i agree overfueling like 5 miles to the gallon lol
its when you sit back and read with a clearer head you see how simple it is to see the answer
mark2
Old 18-06-2009 | 11:36 PM
Šhatter Box's Avatar
Šhatter Box
looking at the pics your rocker cover gasket is on wrong look at the lowcating taps
Old 19-06-2009 | 09:48 AM
muz's Avatar
muz
Wye Valley Hardcore
Its an RS1600i rocker cover so not sure they have the locating tabs I'll check.
Old 20-06-2009 | 03:11 PM
Lee_R21Turbo
Lee takes a bow!!! LOL
Glad you got it sorted matey anyway!!!
31-05-2016 10:28 PM
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 08:45 AM
IAN RS2k
18-08-2015 08:51 PM
track.focus'd
12-08-2015 06:53 PM
rsstav
Ford Focus ST Parts for Sale
11-08-2015 05:19 AM
Quick Reply: Oil coming from exhaust manifold gasket?
