piper or kent
27-06-2009, 10:55 PM
piper or kent
evening all, im after an upgraded cam for my s2 rs. in your opinions which one is better piper t285 t2 or the kent cvh 35 , cheers
28-06-2009, 12:59 AM
orion=mini saff
piper, u might aswell used a half cooked sausage then a kent cam ,seems to be a bit hit and miss if they chew up within the first few months or so!
28-06-2009, 01:07 AM
try giving newmans a call should be able to help you out and will even grind to your spec if asked.
28-06-2009, 09:05 AM
Wouldn't wipe my arse on a Piper 285T2, Kent CVH35k all the way, it's a cam I've proven in 3 sperate cars and it works well (as long as you get one from a good blank which is a bit of a lottery).
Newman would be a preffered choice though
28-06-2009, 06:25 PM
focus rs 1672
Quote:
Originally Posted by
griffo69
like asking if diarrhea is better than constipation
newman all the way
28-06-2009, 06:32 PM
ive not heard much about newman, i take it theyre good. how much for a kit iff them . cheers peeps
28-06-2009, 06:34 PM
Balls Deep!
Same price as most others, around £300. But you then have the ball ache of fitting solid lifters as Newmans dont do hydraulic.
28-06-2009, 06:36 PM
this mite be a dull question peeps but whats the point of solid lifters, wouldnt they sound more noisey that hydraulic..... cheers
28-06-2009, 06:55 PM
I've got a Kentcvh34 kit fitted on mine it's done 14k and had no problems with it so far.
28-06-2009, 09:37 PM
#1 in Spelling Club
makaveli96
You pulled it out to check it? Thats the problem with hydraulics, you may not know of a problem as quickly as you would with solids.
28-06-2009, 10:09 PM
griffo69
Neither, buy a Newman
29-06-2009, 01:07 PM
Bodger of Blackburn
had both, both failed due to lobe wear, both run in properly.
newman cam is where it's at.
that'll be my next investment.
29-06-2009, 11:23 PM
Christian and Beccy
I haven't pulled it out to check it as I wouldn't have a clue how to do it myself but it's been alright so far.
30-06-2009, 11:42 PM
orion=mini saff
just fitted a piper cam i was given, see how it lasts
01-07-2009, 09:48 AM
Wye Valley Hardcore
The Piper 285T2 I took out of my old Escort was worn to fuck, and I mean you could visbaly see the wear and going off the reciepts had only been in the for 16K miles. I've got a Kent CVH34 in mine at the monent which has only done 4k which looks ok but is pretty noisy. I've got a Newman solid lifter ready to go in which certainly looks alot better made.
01-07-2009, 11:10 PM
Should a cam effect the idle much?
02-07-2009, 01:14 AM
orion=mini saff
do tend to make it more lumpy, but not enuff to bother with
02-07-2009, 07:19 AM
when it warms up does it get a bit worse?
Mc5506
05-10-2015 09:57 PM
cos elle
25-09-2015 09:52 AM
