Inner tyre wear - all 4!?!
Recently got a new tyre due to the inner side bearing metal, today I noticed the remaining 3 are balding in exactly the same place. Is this a sure sign that my suspension (all round) is fooked? I could understand 1 or 2 doing it, but all 4?
Tracking is spot on as have had that checked twice recently too.
Is it suspension, of could something else be causing this? Car is lowered quite abit and is polybushed all round.....
I can't even tell you how low it is cos I haven't changed suspension since buying the car years ago. No doubt it's coils have been chopped! Standard struts tho, I know that much.
Probs best to change them anyway....
35mm the going rate, yea?
Adjustable front arms will help mate, but as a rule you will get excessive tyre wear if the car's too low. Mine lowered on coilovers with mef arms wears the tyres fairly even and i've never had to replace a rear tyre through uneven wear......
Just read a thread that says they're more for track than road and can be dangerous if ya don't know what ya doing..... I think I'll just swap suspension and raise her a bit instead.
Just a matter of taking it to a local tyre centre centre with the correct equipment to check/adjust camber (laser alignment preferably), nothing expensive about it. Alot of cars come with camber adjustment as standard, the rst however doesn't lol! Think the bottom arms are around the £160 mark from mef.
07-10-2015 12:56 PM
