Start Problems When warm/Ripping ABS out
Question for all you Knowledgeable people out there.
1. When my S2 RST is warm and i turn it off for say about 5 minutes, when i go to start it again it fires then die's. IT only fires again after turning her over for about 30 sec's to a minute. The pump does prime initially but can hear it when its turning over until after the 30 second period. Is it a dodgy relay or is it a dodgy sensor. When she's cold she starts first turn of key. ????
2. Have any of you ripped out your ABS system of your RST.1 of my belt has snapped, and basically i'm fed up with the spongy fell to the brake pedal. And when your running 240-250 Bhp you need some confidence in the braking dept.
I have heard you can do it, all you need is a Master cylinder from a XR3i and 2 brake pipes made up. Well i am breaking my other halfs XR3i so the master cylinder is sorted. Could i used any of the brake pipes of it so that i dont need any made up.
Your help and advice will be greatly appriecated.
Cheeerrs
Cheeerrs
look down abit m8 or next page for ABS rip out im still using the rs master C but used the fluid res from the xr3i
but if you running 250bhp like me then i hope you brakes are abit better than the standard crap?????????
mark
mark
Cheers mate lots of help there. Shame you cant use any of the pipes that is being thrown away to connect to T pieces. At least got the resvoir from XR3i
Yeah rest of brake system is uprated no probs there.
Jack and the Beanstalk
09-08-2015 07:03 PM
